is this on a crew cab or king cabHere's the pics (finally). My wife was a huge help in manuevering the center plate up into position, a bit of a PITA. Everything bolts up great though, no problems just follow the directions.
I like to know that same as well. What is you cab to trailer clearance? What trailer are you going to be pulling with it?is this on a crew cab or king cab
Yeah mine is not as far gone as the one you show, but it is in rough shape. Did you pick that pipe section up at auto parts place?mjw... you may want to keep an eye on that exhaust flange that is shown in your last picture. My $20 fix shown below...
On an '04 King Cabis this on a crew cab or king cab
No idea on the clearances yet, we are shopping for trailers. Ideally we want a 2H slant with LQ.I like to know that same as well. What is you cab to trailer clearance? What trailer are you going to be pulling with it?
Mine fell off, so I took the tailpipe to Midas, and they fixed me up with the adapter and the clamps.Yeah mine is not as far gone as the one you show, but it is in rough shape. Did you pick that pipe section up at auto parts place?
Actually I should have said Cab to ball clearanceNo idea on the clearances yet, we are shopping for trailers. Ideally we want a 2H slant with LQ.
About 33" from center of the ball to back of cab.Actually I should have said Cab to ball clearance
Thanks for the measurementAbout 33" from center of the ball to back of cab.
It won't matter what order you install what, the hitch goes between and above the frame rails.Hey MJW,
I just bought that same B&W turnover from Tweetys (thanks for the link, saved me about $125!). One question. I'm thinking of doing some C10s and new shocks soon—If I have all the parts at the same time which do you think should come first (installation wise)? Or does it matter.
Just picked up a biiiiig aluminum gooseneck for the horse (1) last night. 5500lbs try, prolly about 7-7.5K with dude and stuff loaded in. So stoked, got a great deal on it.
Sawhhhhheeeet.
Okay, cool. I just thought after the hitch install the pass side shock mount might be hard to access (or something).It won't matter what order you install what, the hitch goes between and above the frame rails.
Post pics of your new horse hauler when you can.
I'll say this—I'm glad I put the shock on first. The passenger side shock mount is now obstructed by one of the hitch frame mounts. So if I ever need to replace that shock, that piece of the hitch has to come off.It won't matter what order you install what, the hitch goes between and above the frame rails.
How did that work out for you. Do you have any problems pulling that trailer. Getting ready to do about the same thing, but a little worried about the weight.I'll say this—I'm glad I put the shock on first. The passenger side shock mount is now obstructed by one of the hitch frame mounts. So if I ever need to replace that shock, that piece of the hitch has to come off.
Unless there is some crazy 6 axis bendy socked wrench I don't know about, and I'd need to be able to see with my hands like a raccoon.
Airbags are awesome. RAS OK but airbags way better.How did that work out for you. Do you have any problems pulling that trailer. Getting ready to do about the same thing, but a little worried about the weight.
Thanks
