vipzach said:A trans temp gauge would be really cool!! I would definately be interested in one of those if they do that! Do post pics of yours though!
helomech said:I have been real happy with mine except for one thing. I have yet to be able to pick up a code with it. I had my airbag light flahing once, and I had my slip light acting up once. On both occasions it showed no codes. I also had a airbag light on my wifes quest that it would not pick up. Maybe it doesn't pick up these kinds of codes or something.
I think the only thing it doesn't show is the MAP. Everything else works, mph,mpg,volt,throttle position, load on engine, rpm, water temp, plus all the things under current, tank, today, and yesterday. I don't remember the rest right now.roy365 said:What are the features available for the Titan with the Scanguage???? Is it true not everything is compatible?
The blendmount is the bracket holding the unit over the mirror.Burgy said:Pull a plug wire or leave the gas cap off, that should throw a code.
cneary812: blendmount?
roy365 said:Couple of questions if you guys can help.
Is the Blend mount seperate? What other ways are there to mount if you didnt want it permanent? Where did you order it and whats a good price?
Thanks.
The Pawnbroker said:Hey I made the mistake of buying mine without the mount. Now I will have to pay more for the mount than I would have otherwise. I don't see anyplace else to mount it. Any suggestions? How hard is it to run the cable from the rearview mirror around to the port?
