Which way are these things supposed to sit? Does the offset pin hole and taller side go to the front? No instructions included.
Discussion Starter · #2 ·
Does anyone know? PRG's mailbox is full and doesn't answer calls. I'm in the process and need help QUICK!!!
I'd assume if they are tapered. Angle to the front
. Thank goodness!! I looked at it again and came to the deduction that the shorter side was to the front and the offset pin hole went further back to move the axle forward and angle the front of the pumpkin upward a little more.......WHEW!!! Thx!!
Working on replacing the tranny mount now, not as easy as some were saying with the lift braces in the way of pulling down the cross member......
ran into the same issue but with the Maxtrac blocks. if the tall side was towards the front you could totally tell it did not look like the leaf spring would'nt be seated correctly.
Reactions: WillieFlo
