Considering our stock box is already setup like a CAI I would think that the change would be nominal. Probably less than 10*. What is bigger I think is air flow volume.
His airbox is in the same position as ours. Sorry but my findings tell me otherwise.anmut said:Considering our stock box is already setup like a CAI I would think that the change would be nominal. Probably less than 10*. What is bigger I think is air flow volume.
Sounds like another secret project to me! :rofl:Blackbeauty said:Just turn your CAI into a beer cooler using dry ice... Kill two birds with one stone...
Actuallt me and a buddy took his windshield washer bottle and ran tubing from it into the car once. Our fluid of choice was whiskey.Blackbeauty said:Just turn your CAI into a beer cooler using dry ice... Kill two birds with one stone...
Dont forget to install a fast opening, direct acting kanooter valve.:bouncy:Brianguy said:I've got it now :idea: i'll weld an air conditioner to my throttle body
I think I need some photos of that. Anyone ever done a ram intake from the hood?AgTitan06 said:Well, before I did my custom ram air mod on my Volant, my intake temp was on average 15-20 degrees warmer than ambient temperature. After the custom ram air mod (5" opening tube ramming air through front grille into cut hole in side of Volant), my intake temp now about 7 degrees warmer than ambient temperature.
I'm in humid south Texas too.
I'll get some this weekend.anmut said:I think I need some photos of that. Anyone ever done a ram intake from the hood?
Done the same thing. OBDII readings for AIT (air intake temp) is no more than 5 degrees over ambient temp.anmut said:I think I need some photos of that. Anyone ever done a ram intake from the hood?
I've tested my Hybrid Volant VS my friend's SE with stock intake.anmut said:Considering our stock box is already setup like a CAI I would think that the change would be nominal. Probably less than 10*. What is bigger I think is air flow volume.
Nice!!! Thanks for adding your findings as well. BTW, thats a sweet looking intake mod with the carbon fiber look and all. Mine is installed strictly as directed, and I went out again last night just to see if it would retain the IAT as i was getting earlier that day. It still stayed appx. 8-10 degrees above ambient air temp. I got my data from my Scangauge II as well. It will be interesting this summer to see what the differences are.gr8titan said:I've tested my Hybrid Volant VS my friend's SE with stock intake.
Same identical vehicle: SE, CC. '04. Even the color is the same. I have the "Scan Gauge" and we hooked it up into the OBD-II ports. We ran our trucks one at a time, same route, same speed, same distance and the passenger wrote the temps at specific locations of the route.
Result: My volant maintained 5-7 degrees above ambient temp and his truck was reading 40-50 degrees higher than me.
