Got an 05 se king cab my interior lights aren't working and the fuse in the dash is good can someone give me some direction
wire in the connector came loose? or where the wire comes off the fuse came loose
its probably an electrical issue. you may even have a short somewhere
The BCM's ( Body Control Modules ) in all Nissan and Infiniti's are known for this failure between 04-08 model years. Once you price a new BCM from nissan you will probably just deal with the problem unless your still under warranty.
i did notice my gear selector lights went out on my console shift. Then i put it back in park and then drive and the lights came back on.
