1 - 3 of 3 Posts
Bought a 2006 Titan LE in May. This fall I engaged the 4 high while it was stopped at about 60 km/hr it seemed that the transmission went into nuetral for a split second and then into gear.I stopped driving in 4 high. While travelling to the dealer for repair it happened again in 2 wheel drive at 100 km/hr. No warning lights or any change in the RPM. Dealer changed out a u-joint and shaft in the front end. Drove for a week and the problem re occurred about 7 times so another trip to the dealer and they changed out the fuel pump. Worked fine for 2 weeks and then the problem occurred again about 20 times in 2 hours of driving and another trip back to the dealer. They drove the truck and it faulted out on them but they say it happened so fast that the computer did not register any codes. However the service manager says that it did indicate a speed sensor fault and after some more tests maybe the valve body. The shop has driven the truck for about 300 km with the fault happening only once for them. At this point it is still at the shop with them saying there is something wrong but because it is intermittent they can not do anything until something fails completely. Anyone have similar problem with this fault or problem? Thanks
Discussion Starter · #2 ·
Just for everyones information the speed sensor and the vale body were changed out and there have been no more issues with the transmission.
1 - 3 of 3 Posts
