1 - 2 of 2 Posts
Here is a fun test I discovered in trying to find a blown fuse. It checks fan, A/C clutch, lights, wipers, rear defogger.
FIRST lift/stand your wipers up so they won't scratch your dry winshieldas they will operate during the test.
Close hood and right hand/passenger door.
Open left hand/driver door.
Turn IGNITION OFF
Turn IGNITION ON
Within 20 seconds push door switch 10 times and turn IGNITION OFF.
Within 10 seconds turn IGNITION ON and leave ON.
If you did the sequence right, the horn will chirp.
It will run a test three times that operates all the mentioned systems. A great pre-flight routine before a trip. Just start it and walk around the vehicle as the tests run.
To cancel before complete, just turn ignition off.
The test was fun but it did not find my blown fuse. It did confirm my running lights were inop but I already knew that.
1 - 2 of 2 Posts
