Great post BBF!
It's a sticky!
It's a sticky!
Even for those of you who have never had this problem, It would not be a bad idea to get an extra relay to keep in the truck.
I think your problem is the battery or a corroded battery connection.Okay I'm in dire need of help... I believe my IPDM is going out.. Here is what my truck is doing... Everyday in the morning it starts fine, starts fine when I get out of class, I strted it at least 15 times today running errands before work. Actually 3 days in a row now , idle is fine, everything is normal. 4 DAYS IN A ROW at 8pm when I goto lunch (I work 4-midnight) it won't start, no crank, no kick from the starter but plenty of power for the lights windows etc... I swapped the Relays yesterday but it still is did it today.... Each night after playing with it it seems to start up at about 12:45 am... WTF?? I'll say this I was In Pismo last weekend and did a little off roading, and some towing if that makes a difference... But I'm typing this from my iPhone in the breakroom, and I really want to fix this problem.. Could it be anything other than the IPDM? I thought perhaps it was the transponder key but I've tried all 3 of mine and still no start.. Also my truck is a 2007 4x4 so it's a little newer, anyone with an 07 or newer had trouble with the IPDM?
What did they fix? This problem has continued, but one night by accident I pushed the button on the fob with the key in the ignition and it started right up. So every time it's not wanted to start since I just push the fob button while trying to start it and it's fine. I just today discovered you can reset the immobilizer system with the key, so hopefully that does the fix. If not I'm wondering what I'll need to replace...I had starting problems similar to the IPDM issue. They replaced the IPDM board and all kinds of things but still didn't work. Finally the Dealer fixed it and said it was something with the anti-theft alarm array. The truck has been starting fine for over a year since the fix.
