1 - 2 of 2 Posts
so yesterday I disconnected the power to my subs so I could flash my truck with the new tunes seymore sent everything went great I started her up perfect. I turn her off to connect the power back to my subs and it sparked I forgot to disconnect the negative terminal. I go to start her to do some data logging and nothing no crank everything turns on normal and it doesn't click like a dead battery . I checked fuses switched the relays around nothing I jump start the truck no change. what else could it be I'm really debating selling the dam thing its one thing after another. I already tried the relay swap from the fogs to the ecm and that didn't help. I read on how you can check if it is in fact the ipdm but now I cant find the information any help would be appreciated ::crying::
1 - 2 of 2 Posts
