1 - 2 of 2 Posts
I have an 08 Titan center 4x4 long bed. I have a loud noise coming from my front end somewhere. It sounds like bogger tires driving down the road. If I keep the wheel straight. No noise. As soon as I turn the wheel the loud bogger noise and the more I turn it sounds like whhup whhup kind of like a helicopter. The noise gets louder the faster I go. I have fairly new tires. Still 80% tread. They are bigger than stock. 275/70r18. But it just recently started doing this. I can't think of what it could be, I've check the wheels for play(bearing) but no dice. Any ideas? It sounds like it's coming from both front tires.
Did you jack it up and check for play?? I just had to change my hub assembly on right side and it started as a little squeak and then went to thump thump I almost thought it sounded like the drive shaft. Mine had zero play sitting on the ground but when I jacked it up it had major play.
1 - 2 of 2 Posts
