I think you have to stay with an 18 inch or larger due to brake caliper clearance. on the 04-06 you can go as small as 17. I'm prety sure that Nissan changed the smallest wheel to 18 inch on the 07 and newer.
That's correct and that also coincided with the larger diameter rotors as well.Fox Delta said:I think you have to stay with an 18 inch or larger due to brake caliper clearance. on the 04-06 you can go as small as 17. I'm prety sure that Nissan changed the smallest wheel to 18 inch on the 07 and newer.
