1 - 15 of 15 Posts
I took my filters out, couldn't stand the decreased air flow.
Skumbag said:
Or is the blower for the A/C & Heater quite weak? I'm used to getting blown away by my old Silverado's blower. Maybe its just mine?
Mines the same way, but it because my a/c vent don't function correctly. The air come out the floor when it is set on face so i get about 70% from the floor and about 30% form the face. The dealer looked at me like i was stupid when i told them what was wrong with it, They told me it was normal:explode: .
I'm having the same issue. My ac/heater blower is very weak. Isn't wasn't like that when I first got it though, and I'm pretty sure that filter has been changed a couple times. maybe its time to change mine again.
· Banned
I dont think it's the filter. My truck didnt even come with one installed from the factory. It flows the same now as it did without the filter. I just think it's not as powerful as other makes. Only time i notice it is when the weather is 95 degrees and 75% humidity.
I don't know if it's weak or not, all I know is after having the A/C on during the summer I have to turn the fan down to about 1/8-1/4 otherwise I'll freeze my nuts off. :D
You know, you can turn the vents so they don't blow on your crotch..... :eek:
Discussion Starter · #12 ·
Man... mine barely gets cold during the summer by the time i get home from my 20 minute drive home.
I swear i have to put my hand up to the vent to make sure its coming out almost. Now I might be overexaggerating a lil but it certainly doesnt make your hair move or nuts get cold.
True, but if I don't keep that region cold (read: shrinkage) then my real size becomes obvious. Makes the wife jealous to have other women checking out my package. :jester:
But it's cool...I drive I Titan.
I noticed that mine blows slightly weaker than my old SUV - but I actually think that it's blowing into the rear of the crew cab and so that weakens the stream.
Remember: NEVER CROSS THE STREAMS.
· Super Moderator
If I manually crank the fan all the way up, it blows like a sonofagun. I leave it on auto mostly though, and in that mode the system apparently doesn't often feel the need to have the fan on high. :dunno:
1 - 15 of 15 Posts
