Sometimes under hard acceleration when the truck down shifts there's a noticeable thump, down shifts a little hard... I have 58K on the odometer.
Ever change the tranny fluid?Sometimes under hard acceleration when the truck down shifts there's a noticeable thump, down shifts a little hard... I have 58K on the odometer.
Nope not yet but maybe it's time?Ever change the tranny fluid?
I would start there and see if that makes a difference. Do you/have you used your truck to haul or pull moderate to heavy loads?Nope not yet but maybe it's time?
I towed my wife's car (about 4k pounds) cross country once and I've hauled my motorcycle around a few times on a trailer but that that's about it. I'll get the tranny fluid flushed and see if that helps. Do we have transmission problems with our trucks?I would start there and see if that makes a difference. Do you/have you used your truck to haul or pull moderate to heavy loads?
Not that I'm aware of. As long as you service the fluids as suggested, you should be good to go. What part of CA. do you hail from?I towed my wife's car (about 4k pounds) Do we have transmission problems with our trucks?
It's a possibility.Could it be axle wrap... how long have you noticed it, has it changed / getting worse?
I'm not familiar with axle wrap, but it has been doing this for a few months now. In only does it under hard acceleration when the truck down shifts. I found the thread discussing changing the transmission fluid so I'll drain and refill this weekend.Not that I'm aware of. As long as you service the fluids as suggested, you should be good to go. What part of CA. do you hail from?
As long as you're under there, do the transfer case also.I'm not familiar with axle wrap, but it has been doing this for a few months now. In only does it under hard acceleration when the truck down shifts. I found the thread discussing changing the transmission fluid so I'll drain and refill this weekend.
I live near Fresno.
Yep, I'd do those differentials too.As long as you're under there, do the transfer case also.
