If you change the oil on all your own cars, it's the same for this truck.
Loosen or remove oil fill cap.
Drain oil from oilpan.
Remove cover plate on skidplate with allen wrench.
Reach up through hole in skidplate and rotate filter until it's fairly loose. Let oil drain down drip chute. Do not take filter all the way off until it stops dripping.
[NOTE: stock filter is installed very tightly on MOST Titans. You may need a filter wrench.]
Remove filter.
Clean up area around filter base, drip chute, and install new filter after applying a bit of fresh oil on the seal.
Replace oilpan bolt.
Fill with fresh oil - 6.5 quarts, IIRC.
Intersperse appropriate amounts of beer throughout process.
Remove filter.
