1 - 8 of 8 Posts
Recently installed Deaver 3 spring pack with Dr shocks. This raised the rear of my 06 CC 3".(4" difference front to rear) Since then have noticed a vibration between 30 and 40 mph. Would like to lower the rear 2" and eliminate the vibration, whats the best approach? Rest of truck is stock. Thanks.
· Super Moderator
Using lowering shackles?
GR8WHITE, haven't yet, just looking for the best answer to the condition. Don't want to start cutting unless it is the best alternative. Have you had to do this mod? If so who's bracket did you use? I know that Greg at PRG sells one. Thanks.
Carbeaux, am referring to the vibration. Thought I could change the drive shaft angle if I added a set of lowering shackles. Feel the vibration my have to do with this condition. Thanks.
I WENT WITH 2.5 DEAVER AND 2" TAPERED BLOCKS WITH BILSTEINS AND I USED THE CST DROP BRACKET AND I WILL SAY THE REAR NOW FEELS BETTER AND SMOOTHER THAN IT DID WHEN IT WAS STOCK. YOUR DRIVESHAFT CHANGED ANGLES AND MAYBE ITS COMING FROM THE U JOINTS NOT LIKING THAT ANGLE? :rockon
sorry bout the caps
· Super Moderator
Sorry, I misunderstood that question. I thought you were wondering how to lower the rear 2".
1 - 8 of 8 Posts
