Is This Wheel a Good Fit?
1.4K views 15 replies 4 participants last post by  Aquaholic
16x8 w/-11 mm offset
For a 315/75/16.
I'm told the 16 will just clear the brakes.
I'd post a link but I need 15 posts to do so.:deathsent
#2 ·
Don't have the answer you need , but just reply to a few posts so you can post your links while raising your total count.
Clint
#3 ·
I've only seen one Titan so far with 16"s. Sorry I don't recall the brand. More than likely you'll have a hard time finding one that does work, as some 17's have caliper clearance issues.
#4 ·
Why would one 16" clear and another not clear the brakes...that don't make sense.:dunno:
Anyway I wondering about the offset on the wheel listed. Far as I can tell it should stick out about 20mm more than stock OR wheels.
#5 ·
All wheels of the same diameter are not constructed exactly the same, not by a long shot. Some 18" wheels even require shaving the calipers. And those wheels will actually stick out 47mm (1.85") more than the OR wheels.
#16 ·
Leaving such a small clearance will heat the brakes up, if it will even fit. Some wheels have a facing on the front that kicks back and might rub on the caliper where other wheels might be flat and not hit.
