1 - 20 of 25 Posts
I thought, I would share a list of info for the Jatco RE5R05A
“Share the wealth of knowledge and go as fast as you can.”
Jatco RE5R05A
Sonnax Valve Body Parts
http://www.sonnax.com/tech-articles/TASC-TIP-12-09.pdf
Oversized Pressure Regulator Valve and Boost Valve Assembly
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-01K :: Part Summary
TCC Control Sleeve Assembly
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-05K :: Part Summary
Cooler Bypass Valve Kit
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-07K :: Part Summary
Reverse Boost Valve Kit, Late Style
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-09K :: Part Summary
Reverse Boost Valve Kit, Early Style
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-12K :: Part Summary
"A" or "B" Pilot Valve Kit
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-13K :: Part Summary
TC Regulator Kit
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-17K :: Part Summary
Accumulator Control Valve Kit
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-20K :: Part Summary
Sonnax Torque Converter & HP Converter
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Torque Converter & HP Converter :: Jatco :: RE5R05A
Omega Machine & Tool Co
Automatic Bushings
RE5R05A Bushing Kit from Omega Machine
TransGo
RE5RO5A-HD2 REPROGRAMMING KIT High Performance
Nissan Reprogramming Kits
Transtar Industries, Inc.
Torque Converter Catalog
Pg 121 DA60
Transtar Industries, Inc. - Transmission Parts - Catalogs
Valve Body Manual
Pg 87, 88
AT Catalog
Nissan Catalog Pg 484
Valve Body Xpress
VBX-Guaranteed Remanufactured Valve Bodies
Alto Products Corp.
Alto Catalogs-- AltoUSA.com
.Save file
http://www.altousa.com/pdf/catalogs/oeiCatalog.pdf
http://www.altousa.com/pdf/catalogs/hiperfCatalog.pdf
http://www.altousa.com/np136.pdf
http://www.altousa.com/np127.pdf
http://www.altousa.com/np153.pdf
Discussion Starter #4
A good place to start is the TransGo RE5RO5A-HD2 REPROGRAMMING KIT. This kit will improve your shift tremendously. If anyone has the misfortune in burning up there transmission, then consider using an upgraded rebuild kit.
Alto 174758 Case Saver for the Nissan RE5R05A: B1 Reverse Brake Case Saver Kit 03+
The spline of steel separator plates can work back and forth to permanently damage the case, causing delayed engagement and ATF metal contamination. Alto Case Savers not only prevent this from happening again but allow reuse of the damaged case.
Alto OEI Original Equipment Improvement
Alto 174756 Input PowerPack Kit
Alto 174757 Direct PowerPack Kit
Install these PowerPacks to increase the six friction drum to seven or the seven friction drum to eight in the Input drum. For the Direct drum increase the five friction drum to seven or the six friction drum to eight frictions. This increased surface capacity will better handle heavy duty or hi-performance applications.
Side Note: These kits are made up of RED EAGLE Clutches and KOLENE Steel Clutches.
174903HPPWR-SK Hi Performance
Includes the OEI 174756 and 174757 PowerPack Kits and replaces the other stock clutch packs with RED EAGLE Friction Clutches and KOLENE Steel Clutches.
To sum it up:
TransGo RE5RO5A-HD2
Alto 174903HPPWR-SK Super Hi Performance
If you need to rebuild your Torque Converter
Alto 174782 Torque Converter
With everything else listed you will be able to replace any part necessary.
God Bless and good luck.
Tommy
Thanks for the STICKY.
Excellent information my man!
Good information, I think my 2nd stock tranny is about to be gone.
Great info, thaks!
Yes, thanks Thrust, great info and for the record, I rate the Transgo Shift Kit as a must do mod just like the Tru Trac and I will make that my second mod to the 07 that is stock other than the TT.
Raybestos makes frictions and steels for the RE5R05A also. I have been researching thier Stage 1 product. It a street strip compound. The have full kits Stage 1 for the V8 version of the RE5R05A. Stage 1 material for every friction in the trans, not just direct and input. I cant find any transmission shops that sell the Raybestos Stage1 product. Does anone know a trans shop that can get ahold of them?
http://www.raybestospowertrain.com/pdf/catalogs/raybestos_catalog.pdf
Nissan
RE5R05A
Clutch Pack® Module 02-UP Stage-1 V8 RCPS-197
Discussion Starter #12
Nissan
RE5R05A
"""174903HPPWR""" Hi Performance
Includes the OEI 174756 and 174757 Power Pack Kits (The OEI adds extra RED EAGLE and KOLENE clutches to each pack) and replaces all the other stock clutch packs with RED EAGLE Friction Clutches and KOLENE Steel Clutches.
If you want the Super Hi Performance kit, you will have to order part #'s 174950 (band) and 174940 (filter) to go with part # 174903HPPWR.
ok guys so just to make sure this is a tread on a upgraded tranny? and i was thinking to get that shifter kit. but im not sure how it goes and what are the benefits.. thanks guys..
Discussion Starter #15
Subscribing for future reference! Thank's Thrust!!!!
ok so far i have the shift kit and after some abuse the kit now is working properly, so far the only issue that i have heard(every time my wife hits Baja i cant go) is that when 4LO is engage the VDC doesnt disconet and they have to do it manually.
so this are all the parts that i need to have a bullet proof and offroad ready tranny , correct:
To sum it up:
TransGo RE5RO5A-HD2/ DONE
Alto 174758 Case Saver what is it for?
Alto 174903HPPWR-SK Super Hi Performance what is it for?
Alto 174782 Torque Converter and the name explains it in common sense, but again im a Marine so common sense in uncommon
so where is the best place to to get this items. thanks guys/...
1 - 20 of 25 Posts
