1 - 6 of 6 Posts
Hello, I have a 2005 crew cab 4x4 SE with 165k. Yesterday it started making a weird jingling bell sound while idling. It’s loudest under the truck on the drivers side near the bell housing. Only happens when idling and stops the moment you give it any gas. Any ideas?
Now I'm intrigued...im.sure someone here will know exactly what it is.
Sounds like you have small parts loose in the bellhousing.
Discussion Starter #4
So Upon further inspection I took the inspection plate off of the Bell housing, turn the fly wheel with a screwdriver and made sure each bolt was torqued. Started the vehicle and by putting a screwdriver to my ear and listening to each component i’ve came to the assumption that there is something inside the CAT that is rattling around. I took a small hammer and hit it a few times and you could hear something bouncing in there and making a pinging noise.
Not good. Time to call Cajun.
1 - 6 of 6 Posts
