just installed PRG 2" leveling kit
588 1
on 05 LE 4x4 (non big tow/non off road)
I'm 100% sure it was the correct kit by my front is now sitting at 38.5" and my rear at 38".
Any thoughts??????
1 - 2 of 2 Posts
It might take a little longer for your springs to settle in but it's normal with the kit for the front to be a little higher then the back. You might hear front end clunking too, maybe not, but that is also normal because you've raised the front a little higher, loseing some downward travel. I've trimmed my coil bucket and the upper control arm and it's helped but much better to get PRG's upper control for longer downward travel and clearance for the upper control arm and coil bucket.
1 - 2 of 2 Posts
