1 - 11 of 11 Posts
Hi all. I was wondering what your thoughts are on a K&N cold air intake for a 2017 Titan SL 5.6 liter gas model? I asked my dealer if one of those would void the warranty and they did not give me a straight answer as to a yes or a no. Anyone here with the same motor as mine tried out one of these K&N cold air intakes and if so are they worth it and will Nissan warranty the engine if something major happens?
Terry
Each dealership is different but my understanding is if something happens to your tranny, they can't blame the air intake. It would have to be something related to the intake is where you may run into an issue. I've read some dealerships not caring at all, and others saying any time they had warranty work they would take the intake off to be safe. It's hard to say but I would think your dealership would be the ones to give you the ultimate decision.
I'd love to know what "magic" materials they use in a K&N that can filter to a smaller micron size than OEM, yet still improve air flow, without changing the size of the actual filter. In the motorcycle industry, some street bikes swear by K&N, but in the Adventure, Dual Sport and Off Road segments very few people use them. I've seen way too much dust on the upstream side of a K&N to want one in my own vehicle.
IMO K&N is overpriced and if you do some research it does not add the HP they claim. On a dyno maybe, they really hype it up, it's called Marketing. You may see a slight increase in HP but with 390 hp from the factory, how much more do you really need?
I had a K&N on my Rousch Mustang but I could justify it with a supercharger. Personally, I think it's a "fun" thing to do for a mod but I also think it's a waste of money for a stock engine.
I used a K&N air filter on my old 2000 XLT Triton engine and it gave me a nice little boost. Better performance I got out of the old girl. I should have tried the cold air intake, would have been an interesting experiment.
Discussion Starter · #8 ·
Its not more horsepower that I am trying to get out of the engine its the airflow for better performance. I agree they are over priced for their filters but on the upside they will last a long time and with the dealer charging 45 bucks just for a basic stock air filter I am already on number 2 filter, that will add up quick.
if you want better airflow, open your stock filter box and see if you can remove any barriers that cause the air to make any turns right before going into the tube to the intake. maybe see if the opening into the box is smaller than the tube to the engine and if it is, enlarge the opening to match. and do those openings match the size of the throttle body.
you can probably smooth the airflow track out and mmaaayyyyybbbeee get a little more flow by adjusting openings to be the same size, or larger then the throttle body opening, but other than that, without going to an oversized throttle body, you are really just messing around for fun. your stock box is already a cold air system that also cuts down on engine noise. a k&n, or other aftermarket system just gets rid of the noise reduction so you hear the revving and "feel" its faster. and most of the aftermarket kits actually turn your stock cold air intake into a warm air intake by not properly sealing out the hot under hood temps and using highly conductive metals that transfer heat versus low conduction plastics that are way thicker to help stop heat transfer.
unfortunately, if you put a temperature probe on that intake tube in the pic above, and one on a stock intake, the air in that metal tube will be a higher temp than a stock system so you are lowering hp running hotter air with more widely spaced oxygen molecules than cooler compact oxygen molecules.
how much though, you would have to run on the dyno to find out. most of the time those aftermarket intakes actually cost you horsepower when you actually run them on the dyno.
1 - 11 of 11 Posts
