hey just mondering what air pressure everyone is running in the kumho a/t tires it says max 44 on the wall of the tire so idk exactly what would be the best hot / cold pressure any feedback would be great thanks
well all the tire will tell you is the max, cos it doesnt know what vehicle its going on. just look at your service plate in your door jam and it will tell you what pressure to run. for winter, sometimes people go 1-2 psi over because the cold weather can reduce the pressure. then again, as your tires run and warm, they will gain a little in psi. sometimes it can be a wash. you can always put nitrogen in the tires, that way the psi will stay more constant across the season.
