Is there a large oil filter to replace the lil bitty one that's stock?
Thanks
Thanks
You using this? :hi:Blackbeauty said:Amsoil also makes a bypass system that will work:
http://www.amsoil.com/bypassfilters/2007_Nissan_Titan.pdf
No, but it's interesting. I know a few guys with some fairly built motors who swear by them. heck, NASCAR uses them, so they must be sent from the GODS , right? :lol:roy365 said:You using this? :hi:
Has anyone??????
If large filters are so great, why didn't your truck come from the factory with one?BrokeRecord said:I want a larger filter because I want one. I've always used larger filters on everything I've been able to find. Probably 75 vehicles. If small filters are so great,why don't fleet vehicles use them? Or if they are so good,why not get one the size of a thimble? A large filter will filter more dirt then a small one. I read with interest all the pros and cons on the best oils and reading your used oil, why not get more filter while you're at it?
If you want one because you want on that is fine. If you think it will filter better you need to do more research. A large filter will not necessarily filter more dirt, the housing may hold more dirt, but that is it. How long do you plan on going between oil changes? Many of our engines have filters that are less than a inch wide, and 2 inches tall and will filter way better than any car or truck filter. In the older days when engines produced lots of blow by and had crappy bearings the bigger filters where a must, but now there is no reason for it. If two filters have the same flow rate, and filter down to the same micron level than the size is irrelevant during a normal oil change interval.BrokeRecord said:I want a larger filter because I want one. I've always used larger filters on everything I've been able to find. Probably 75 vehicles. If small filters are so great,why don't fleet vehicles use them? Or if they are so good,why not get one the size of a thimble? A large filter will filter more dirt then a small one. I read with interest all the pros and cons on the best oils and reading your used oil, why not get more filter while you're at it?
You don't HAVE to mount it where they say. But you may need to have some additional hose fabbed up if you decide to go further away. The main thing is just gettig the components and deciding whats best for your application. For a strictly street application the AMSOIL is fine, offroading? Maybe not.54warrior said:That Amsoil setup really puts the filter in a place which is really susceptible to damage if you ask me.
Not in this case.:jester:Blackbeauty said:So.... you're saying size DOESN'T matter? :huh:
