Thanks,Looks good.
Not my cup of tea, especially making holes in the skin, but good work.
Wires run along the frame up to the relays (2) one wire is grounded to the body just where the parking brake cable is. Just a side note the frame is NOT a good ground had it there and lights would work then not. The Negative side of the battery goes to the body of the truck not the frame.I see you ran your power supply down the back window. From there where does it go? Did you install a relay and a switch in the cab? Show picks of the power run and switch set up on the dash or where ever? 3M tape huh? and that holds it firmly in place? Is that a seperat mounting piece then the light bar mounts to that piece? I like the idea but not the power cord down the back window.
