1 - 3 of 3 Posts
My 2004 has developed a clunking noise from the right rear, especially when accelerating over uneven pavement. Putting 2 and 2 together, I think there's a chance that the rubber that's presumably in the front leaf spring bushing got cooked by my side exhaust that's right below it.
What's involved in replacing this bushing? Are there aftermarket bushings or should I go with a stock bushing (Courtesy Parts has them)? Who sells a new bolt (not listed on Courtesy Parts)?
Thanks very much.
The shackles might be failing. I'd do some inspecting before I guessed what the problem is.
Forgot to mention that the truck has aftermarket shackles (DirtKing) already.
But absolutely correct to point out to investigate before guessing and buying parts.
1 - 3 of 3 Posts
