1 - 16 of 16 Posts
I drive a 2005 Nissan Titan LE, has 94,000 miles. On a 120 mile trip I noticed a clunking sound so I decided to pull off and investigate. Initially I thought something was rolling around in the bed of the truck so I opened the tonneu cover. To my surprise there was a big bulge on the truck bed. I am not a mechanic so I thought it may have been sun damage or bulging from heat or something. When I tried to stomp the bulge down with my foot it didn't move. That is when I decided to look under the truck. That is when I noticed the Leaf Spring Shackle had failed. Glad it didn't go through the bed like some of the other people have posted. I am having both sides replaced at my mechanic.
2004 through 2007 Titans have shackles that are very weak. Make sure your mechanic replaces the shackle with a 2008 shackle. They fit perfectly and are much improved.
Reactions: Jet747 and IbChris
Super Moderator
Sorry you had to find us this way. :( Unfortunately, that shackle failure on the pre-'08 models is a known issue. Especially in places where roads are salted in the winter.
Reactions: Jet747
This definitely should be a recall item, but nothing will be done until some innocent party is badly injured/killed.
Reactions: Jet747
Discussion Starter · #10 ·
Carbeaux, although I live in NC right now we did just move from MN where plenty of salt is used nearly year round. Are there any other "known" issues that I can have the mechanic take a look at while he is replacing the 2 shackles? Thanks again.
Just had this happen to our Titan. 2006, 65,000km
Truck was driven in salted roads.
What sucks is I have a Worlds Jet Boat Race in a day. So I have to find a replacement in time.
Thanks for the info on this thread.
Kinda off topic, but does anybody know if the spring tech drop shackles are a suitable replacement? My current chuckles are fine, but I wanna drop the t
while on the topic of leafsprings, i have 2000kms on my 2011 now and my driver sde has a slight squeek. normal? or should i get the dealer to do something about it. but the weather is starting to get cold
i greased the up thismorning now i gotta wait until after i drive home from work to work in the grease but has anyone else had a squeeking problem? 2000kms isnt alot of mileage to be making noise already
1 - 16 of 16 Posts
