My truck has developed a "roar" that sounds an awful lot like a bad wheel bearing; however, when looking at my truck I noticed wetness inside my right-rear drivers wheel. I have a 2004 crew cab and 4-wheel disc brakes. Could this be the sound I hear? Is it leaking brake fluid and a stuck caliper piston?? I have attached pics. One side is the passenger side (normal side), the other is the problem side. Thanks!
- Chris
You need to replace the rear axle seal.
yep rear axle seal, that's differential fluid. The roar is probably dried out gears and or bearings.
