I just removed my mini lift kit and replaced it with Radflo 2.0's. The install when perfect, but I now have a 1 drop every 5-7 seconds from the front axle where the flange is. It appears that the flange pulled out from the differential about 1 inch, and is dripping from that point. Can I just push/knock the flange back over to the differential? Will driving the truck with the leak cause any further damage as long as I don't use 4 wheel drive?
I need advice?
Thanks!
I need advice?
Thanks!
