1 - 3 of 3 Posts
Hey newbie here I have a question I put some led strip lights along the rails in the bed of my truck. I ran the power source from my battery but there lighting very dim I have them on a switch everything is grounded well and I checked voltage at my switch and I have 12 volts not sure what's wrong tested the LEDs before I installed them and hooked them directly to the battery and they work fine
Bad connection or bad ground. Aldo make sure the switch is good.
Thanks i read the post before mine about them after I posted it was a bad ground thanks for the response
1 - 3 of 3 Posts
