1 - 3 of 3 Posts
I installed led reverse bulbs and they work fine. Then I installed the driver side signal & marker light along with the license plate bulbs. First the signal led would flash really fast and then it wouldnt turn on at all. Now my signals work but the marker lights dont turn on, neither do the license plate lights. Did I blow a fuse or something? Also, how do I wire up the load resistor?
One time, I tried an LED Bulb, it blew a fuse in the Fusebox near the front passenger seat. I'd forgotten that fusebox existed, had checked the ones in the engine compartment. I found out when the dealer told me! $50 lesson.
Another time, I don't recall exact circumstance, I had OEM taillights working but not the LOF Taillights. It was because of a small voltage drop, caused by a jumper wire not having perfect contact right on the blade of a fuse. Reinserted the jumper wire and fuse, and all was OK. Circuit was correct, but not complete. :)
Could you tell me which fuses I should check?
1 - 3 of 3 Posts
