Better check tongue weight. If you are dropping that much you must be over on tounge weight. I can put 1000 lbs on my hitch and dont drop like that. You may need eq hitch or air bags. Helper springs do go up to 1500 lbs but I have never tried them .
buyouts said:Well I installed the RAS the other day. Towed my 16' enclosed trailer full. Worked great. On the way home after droping off trailer I went down I95 at 80mph and the rear end was all over the place, swaying around I couldn't beleive the way it handled. I guess I need a rear sway bar now and maybe drop the rear.
buyouts said:I only have 25k miles so I wouldn't think it is the shocks. Tighten it up more then they say to.. I'll check it again this weekend. It did raise the rear a bit also..
