I have a 04 4x4 KC with only 23000 on her. Here's my list of probs so far. Leaking front axle seal when they were replacing that noticed metal chunks in front end so had to replace my entire front end. Cost 2300$. I was noticing a loud noise, so I took her in and after searching forever they noticed the engine had come loose. I drive another 2000 miles and all the sudden notice another loud noise. take her in and they discover that the transmission has come loose. Shop also noticed that my rear axle seals were leaking, when they were replacing that they pulled the diff drain plug out to have nothing drain out. Turns out the hole was completely blocked by broken chunks of the diff. Then they found axle damage. So they had to replace that.
Thank god it is still under warrenty, as the repair cost is getting close to $$10,000.
anyone know if that is enough for a lemon in ca???
