I installed a leveling kit on my 06 Titan and everything looked great. Then a few months later I installed the Firestone airbags on the rear. Now the airbags at 10lbs have raised the rear end just enough that it looks like I no longer have a leveling kit. If there anything I can install on the front to level it out with the firestone airbags? Anyone run into this?
Mine looks fairly level with the same setup. Is your truck 4wd? If it isn't, then you could go with the 2.5" kit. You might be able to contact prg, and get some adjustable front struts.
Around 10 psi, maybe a little lower. I think you are allowed to go down to 5psi, but I might be mistaken.
