Good info, thanks.It all depends on what year titan you have.
I have a 2.5 inch level kit on my 05 2wd titan and I am at the limit of the camber adjustment without having to buy PRG camber bolts. I also installed bilstein HD shocks. It rides way better than stock because it is not riding the bump stops any more. And it is not close to hitting the coil bucket on min at least.
I think a good set up would be the 4 inch lift spindles with a 2 inch level spacer with some bilstein HD shocks. The spindles are a little cheaper than shocks and by it self it gives you more lift than a coil over shock alone. So for 6 inches of lift it would be around $1300.
If money is tight the Bilstiens and a level spacer would save you way more and offer a better ride than stock.Good info, thanks.
I think I am gonna end up just getting some coilovers and use that as my leveling kit. I just want to fit 33's, so if I need to go any higher I will just get a body lift. Im trying not to spend too much on it, but since I need new shocks I dont have much of a choice.
