1021 - 1040 of 1063 Posts
The guy from RC is wrong, your right, anything over 1.5" on your 13 4wd will require UCA's. Get a 1.5" billet aluminum spacer off ebay, it will be less expensive and hold up way better.
Quick question. Do rear blocks (1 or 1.5 inch) hurt the truck or stress out parts?
I'm debating adding a rear block with Billstiens 5100s on the 1 inch setting with new UCAs up front. I already have a 1.5 inch front level. (09 4x4)
I have 1” blocks in the back of my 15, and have since new. I haven’t noticed any I’ll effects from it. I did add longer rear shocks, but I think with a 1-1.5” block the standard ones are still fine.
No it shouldn't
I bought the 1.5" aluminum spacers off ebay and had them installed today. They leveled my truck perfectly when I measured it today. It was 39.25" from the ground to the top of the front and rear fenders. It also feels like my truck is riding a bit better after the level.
What Gen Titan? And do you have any cbc?
Question and ive read all 104 pages!! Kinda getting mixed opinions......i wanna level my truck or even get a little more lift without cbc. After doing my homework......will a 1.5 spacer plus bilstein's at medium perch.......give me a 3" front lift....then ill just add 1" block at the rear........level my truck? And give me 1 inch higher all around without cbc? Trying to avoid buying expensive control arms.......from what i read the billys act like a 1/2" spacer regardless of the height setting.....and the highest setting is too harsh of a ride......right now as i measured my 2004 2 wheel drive Titan sits 2" higher in the front......opinions please....didnt wanna start a new thread and ive tried doing as much as research but im still confused....if the setup i want is possible......
Well here is the pic of the truck leveled out 1.5" spacers and 5100's all around. Front set on middle perch. 275/70/18 duratracs. Next on the list is new tint which should get done next week.
So Creavis......are u 4x4 or 4x2 also what yr??? Sounds like im doing what u did......bilsteins all around at medium setting (1.5" lift) plus 1
5" spacer.......any cbc ??? Also i assume its .5 inch higher in the front?? I plan on adding 1" block on the rear.......let me know....thx.....
i have a lead on a set of 325 60 r 18 tires / rims for a real good price
problem is, i have a 2010 4 door 4x4 titan.....its got the factory rake still
so would i be able to clear these tires with a levelling kit and some wheel spacers?
so let me make sure i got this right before i order all these parts.
i have a 04 2wd Titan.
I put 5100s on it a year ago because the front struts were shot. put them on highest setting and still have some rake.
if i put 5100s on (counts as a .5 inch) with a 2inch spacer that will be the max i can get correct? (2.5 is max for 04 2wd)
was thinking bilsteins at middle perch and 2inch spacer. i think that gets me an inch more than i have already i thought i saw something about bilsteins changing length over the years which has me a little confused and wanting to be sure
I cant answer your question about the 5100's but i do remember reading about the change as well. I wanted to suggest you change springs instead of adding a spacer. I had a 2" spacer which helped marginally and then I realized all the nose dive and poor handling was still there, it just sat higher up. I have an 06' 2wd btw. If you have the same symptoms you get much improvement installing the moog 4x4 springs. They run like $80 and give you lots of lift in addition to improving handling drastically.
wheel spacers will make any rubbing issues WORSE. you can clear 325/60/18's easily on a 9" wide wheel with a +20 to 0 offset....just do PWM and leveling kit.
