Lift for Pro-4x???
1082 Views 5 Replies 4 Participants Last post by  BleedCrimson33
Ok so it looks like after my accident two weeks ago totalled my 04 CC SE 4x4, that I will hopefully be a new owner of a 08 CC Pro-4x, looking for input on the different small lift setups for the Pro-4x (ie 4" and below) just can't afford to do a 6" lift and really dont have a need just want to give it a little higher stance and improve clearance for minor offroading. I was going to go with the RC 3" on my 04 and 5100 Bilsteins but not sure about the Pro-4x so as always TT.COM help me make a good decision.
Thanks
G
1 - 6 of 6 Posts
Go with the RC kit but you will have to get a 1.5" spacer if your going to use the 5100's .
is there a better setup to get closer to 4" WITH OUT running the 5100's ? and I am still new to the lift thing, what is the problem with running the 5100's with the RC 3" or 2.5" spacer i should say
since the truck is a pro4x and an 08 the coilbuckets are higher on the frame, and the 4x4 has the truck sitting a little higher anyways. using 3 or 2.5 spacer obviously lifts the truck, but the bilsteins also lift the truck about .5 even on the lowest setting, so the ucas are gonna be riding on the coilbucket. very recently someone did this and showed a picture of the ucas on the bucket, it was pretty bad. and there are actual lift kits that run you over 1000 dollars for 4+ inches. 2wd is easier cause all you gotta do is get a spindle and spacer, but we cant cause than the differential will get fubar'd. This is my understanding of it, hopefully someone else will say somethin. check out prgproducts.com too.
What's your price range?
well thanks for helping out guys but went to go get the Pro-4x and decided on a 08 CC LE 4x4 with 39K miles and a extended warranty on top of the stock warranty :) just couldnt turn down the deal, it was a one owner and the guy was like 70 yrs old the truck looks like it is brand new still ... but think I will end up finally doing the RC 3" lift with bilsteins 5100 on it
1 - 6 of 6 Posts
