I just got done installing the Rancho 4inch (more like 6) lift, now the Slip, Brake, and Air Pressure lights are lit on the dash....have I over looked something, do i need to reset the comp., anyone else had issues like this???
I'm guessing you ran out of fluid while bleeding the brakes for the stainless lines? Regardless you need to make sure that you bleed it several times b/c the ABS is a little sensitive to air and could end up damaging the sensors....
