Lift Kit?
788 6
I am wanting to get a 2.5"-4" lift kit for my 08 Nissan Titan and I was wondering if anyone had any suggestions on which to get or pictures on any trucks with the 2.5-4" lift.
Also, how is the gas mileage effected with the lift?
Thanks in advance.
the 4" spindle lift is the best option, then a 2" block in the rear would make it level or close to it. and you could run a 35" tire more than likely...PRG Products
2wd or 4wd?
4" spindles w/ 1.5" spacer. The 4" spindles don't make the truck look or feel that much bigger. You will be able to go with a wider tire/rim comber too, and it's cheap. You can usually find cheap spacers in the buy/sell section. Get a deaver c-30 pack for the rear with some bilsteins. You will need a carrier bearing drop bracket as well. Go with some light 33's all terrains on an 18" rim and you will be good. Expect to loose 1-2 mpgs as well, maybe less depending on the final exact specifics.
