Is there a light bar kit that easily installs a 20" light bar in the grille? I have seen a few members have light bars installed there, and I see that Rough Country sells mounts, but only for the XD. I have a 2017 Pro4X.
Thx
I mounted mine inside the grill, the top grill. I drilled holes on bumper and had to rig up some extra pieces of metal to mount it farther back in order to clear. I think mine is a 23-24 inch. I'll try to take some pics after work.
I am looking for the one that fits in the bumper, not the grille. Maybe this one... https://www.rigidindustries.com/mounting-options/46581
Do you have to cut the plastic in the bumper slot, or does that simply remove?
I just looked at your post, I have an 04 so probably a lot different set up but here is how mine looks, it's a 28" with 1 4" mounted at an angle on each side. Good luck finding something that works.
I'm not sure, but I just had another look at the pictures and realized that the Titan in their images is an XD, not the base. The XD has the tow hooks below the bumper whereas the base, when equipped with tow hooks, has them in the same opening in the bumper as their light mount.
Rough Country also sells a mount for the lower bumper, again showing it on an XD.
Yeah, I contacted Rough Country. Their model ONLY fits the XD.
