265 70 18 are 32.5 tall so basically tire vs tire you will raise the truck 1.25". Then you can go 82-77= 5" lift and be almost 2" under the garage. More importantly, is your driveway perfectly flat, does it drop from your garage, or is your garage lower?
If the driveway is lower than the garage..... Then you will have more clearance than you think.
If it is the other way, then you might be screwed.
Pull your truck 1/2 way in and measure the difference.
