Reposting this here as I posted in the wrong place earlier.
Hi everyone, im looking at buying a used Titan in my area and will be heading to see one tomorrow. It's a 2010 SE CC with a lift and 35's.
The add describes the lift as:
6" ProComp lift with 2.5 Radflo Coilovers up front Bilstein's in the rear
6" lift with coilovers, not maxed so there is room to get bigger (sits at 83.5" so it will fit in your 7ft. garage) Traction bars installed, this prevents rear axle flex/twist. This lift was professionally installed and done right.
Is there anything I should be specifically looking for with the modifications? Is there any additional wear running 35's? The truck has 60k on it.
Thanks in advance.
Sent from my Nexus 5X using Tapatalk
Thanks in advance.
