lookn for advice
1136 Views 15 Replies 5 Participants Last post by  duke01
have a 2x4 2004 titan and im lookn to lift. it im shootn for 9 inches in the front and about 7 in the back. i want it to be all performance because i go out to gorman, pismo and glamis, and lookn to kick some a$$ out there. any help, pics, or suggestions would be great thanks!!!
1 - 16 of 16 Posts
Do you own a set of paddle tires?
Which do you want, performance suspension, or 9" of street lookn' bling? Make up your mind...
maby i wasnt clear PERFORMANCE. im not about shown off on the street...im more intrested in kickn but off road
It was confusing, you mentioned performance AND 9 inches of lift....
PRG Products has a 4" Performance Kit that "kicks butt" and he's coming out with a mid travel kit very soon, either way stay away from the word "lift' and people will understand when when you use the word performance...
http://www.prgproducts.com/titan_performance.php
what lou's trying to say duke, is that with 9", you'd get a good looking set-up perhaps but the high COG will not be all that performance enhancing in the desert and dunes.......
but if it's 9 your after, you could go with the CST kit with extended SAWs in front and a set in the back w/a full leaf pack (small block perhaps if you want 7)............there's a pretty good thread that went on for a few pages about best set up for the desert, you ought to check it out.....
THen why would you want a 9 inch disco lift? They are totally opposite.
ok got ya, sorry for all the confusion, im new so...
i said 9 inchs cuz a guy at the desert had a titan with about that much on the front so i was talkn to him about what he had on his truck..thats all
ok what about this set up... prg upper control arms, cst 4 lift spindles, 2.5 deaver springs... but what shocks should i get? and am i missing anything
That is a good setup. SAWs for the front.
TO take it to the next level add some airbumps and 2.5s on the rear.
ok this might sound dumb but what exactly are air bumps? and what size do i need?
Don't take this the wrong way but I don't think if you're going out to the "dunes" your going to be kicking @ss with a 2x4. Without a 4x4 your most likely going to get stuck in the soft sand and need some ones help to pull you out.
kartman is suggesting a great set-up though!
maby, im not guna be out in the soft deep stuff, got a friend with a 2x4 and it can hold its own.... dont get me wrong a 4x4 would dominate but it wasnt in my price range...especialy while going 2 college!
cartman, ok so doing some reading i found out what they do... but i still could use some help on what size i would need...thanks :cheers:
Call PRG, they can set you up with everything that will work together properly.
duke...here is his phone number: 951 780-5331
awsome thanks 4 the help!!
1 - 16 of 16 Posts
