does anyone know what is the lowest one out there and where can i find one for sell. i went to napa but they only had a 170* and the stock one is 180*
my friend says there should be 160* but cant find one
I'm not sure you want a 160....if the Titan don't hit 176 I think it is your ECU will get mad and throw a code.
I personally use a 1996 300Z 170 degree OEM thermo stat.
I did a slight modification to the cage on the back of it....truck runs 183 all the time compared to 190-195 before.
^^^Good advice, heard a lot of this code. Use the search to pull up threads on this as some guys here have already put in A LOT of time on this mod.
RCH2 said:
thanks for the info. napa had a 170* in stock for the 06 titan. would this work for my 07 ??? im sure it would but just asking anyway
Seems like most who run the Stant or Napa or similar 170* stat have problems. Some have modified the Stant and work great. I did what Rossi did and cut the cage off the 300ZX OEM stat, been running about 177 (been cooler here lately)
with high of about 183. Compare to 190-195 before also.:D
