So I am changing out both ball joints on my passenger side and I got the upper balljoint out with no problem. Then when it came time to remove the lower bolt that holds in the lower ball joint to the spindle, it was completely rusted on. The head of the bolt became completely stripped so I cut the nut off with a grinder but the bolt still will not budge. My question is if the spindle is also threaded because the bolt will not budge even when hit with a sledge and punch?
