I purchased a set of 2nd gen Pro-4x wheels that unfortunately didn’t come with lugs. I need lug nuts to install them and do not want to spend $240 that the dealership is charging for new ones. Can someone point me in the right direction of something that would work for me? I am looking to install them on a 2017 Titan SV 4x4. Again any help is appreciated!
2017 Nissan Titan S 4x4 single cab
I just put 1st gen Pro-4x wheels on my 2017 Titan S and was able to use the stock lug nuts that came on the steel wheels. I researched aftermarket lug nuts, and I think the standard Titans (not the XD) all use compatible ones. The lug nuts for the steel wheels have the wide flange to hold the plastic hub cap on.
542873
542874
Check around at customer wheel shops or find a wheel repair place in town. They should have an assortment of suitable lug nuts from known brands which are far cheaper than OEM, but equally workable and usable.
Look up the
Mc Gard Wheel Nut 64003
Supposed to fit all Titans except XD, you can even get them at Autozone. But I bet your stock lug nuts will fit fine, as long as the new wheels didn’t come off an XD.
