1 - 8 of 8 Posts
Oh no. I can't wait to see what some of the comments are about this post.
if you mean thread and pitch, it's 12 x 1.25. then it's just a matter of finding the correctly sized head/socket that will fit the openings in the wheel.
a 21mm socket will do the trick. BTW if you've got aftermarket wheels (as i've found out) you need a thinner walled socket to access the lugs.
That's under 1/2"...Are you sure it's only 12mm?
Absolutely, it is a 12mm x 1.25mm thread.
OK, just double checking...Kind of wimpy aren't they...Suprised we haven't seen these compared to the F-150's...
1 - 8 of 8 Posts
