1 - 20 of 44 Posts
I put on my MAG HYTEC rear diff cover and Stilltimes FSB mounts today!
I'll start with the cover, this thing is sweet looking! I almost didn't want to mess it up by installing it! I am digging this cover a bunch!
It was an easy install, drained the oem fluid from the drain plug on the axle housing.
Removed bolts, then popped the cover off. Scraped off all gasket material with a razor blade, then wiped it off.
Installed new cover with reusable gasket and tightened down all the bolts in a cross pattern. Only thing is the bracket did not line up with the holes on the cover so I was only able to use one hole on the bracket...I would like to know what other Titan owners did here with that incase I did it wrong...
Filled with 3.5 qts of Super Tech 75W-140 full synthetic. 3.5 qts put it right in the middle of the high/low lines on the dipstick.
My axle drain plug did have very fine metal shavings on the magnet as seen in photos below:
Stilltime FSB Mounts and Bushings were the highlight of my day to install! These are some badazz swaybar mounts! I could not even get any play out of my swaybar with these installed like I could wit hthe OEM marshmallows! Much better performance wise over OEM. They feel stable and true, I believe I have gotten my grounded feeling back.
Lookin good man. talk about a complete truck.
My installation of the Mag went just about the same including only being able to get one side, the same side, of the bracket attached and having a small amount of junk on the plug. I see you have access to a lift, nice! I had to do mine lying on the ground.
4.5 quarts put me at the top line when checked on the ground after driving around a bit.
The NISMO bar looks great next to the new cover.
I had to rattle-can my axle so it didn't so obviously nasty next to the new cover.
Hector
Discussion Starter #7 (Edited)
Hector
Thanks, cool, good to know...i will put it back on the lift tomorrow real quick and check the fluid level, i still have a half a quart left if i need it...
ya i don't know what to do about the bracket...i mean its not going anywhere it is tight but just looks un finished imo...
I agree but in my case the only person other than me who will see it is my mechanic and he is pretty unfinished looking himself. :)
Doesn't MAG sell a bracket?
I think it might. It is cut at a more severe angle and has less unnecessary meat on the side that will be against the cover.
Kinda pretty. Damn....
GBs can get me in trouble. Lol
Sounds like a plan. For some reason $30.00 comes to mind but I don't know where I saw that number.
I might be in for that.
1 - 20 of 44 Posts
