Heading home from work yesterday running great an get the 3 lights of death slip, abs, an ses truck died on hwy coasted to a gas station. Disconnected battery an set for a bit an did some tried to restart an would crank no fire. It was dark couldn't see so got towed home pulled codes this morning p0605 for ecu and P2020 & P2021 for accelerator pedal sensor. Truck started but would die instantly popped hood to find my cold air had popped off from the throttle body must of hit a good bump an it worked loose reattached an cleared codes an running great. To those that may have this happen to you check air intake before spending money on stuff you may not need.
