Well, you could. But you'd have to redesign the front wheel hub assembly and do it in such a way that the axle stub-shaft is supported at the spindle and also so that it would fit an existing set of manual hubs. I guess if you're creating one-off parts for the bearings, you could create your own one-off manual hubs, too. And some wheels with a big enough center section opening to get to the hubs...
I wish we had the option. I suspect it would give back 1-1.2mpg when unlocked just from the lowered rolling resistance.
