beermunk said:
Oh my I can't imagine the computer work that would need to be done. He must've had an inside track at Nissan to get that done. I mean, it's something else to switch trannies on my '69 chevy...
The car is driven by Chris Forsberg and run by Drift Alliance.
They had to use a stand alone AEM engine management system due to the electrical complexities and due a Q45 throttle body. They still had to cut a hole in the hood for clearance.
It can be found in the December 2006 issue of super street.
Specs for the engine:
JWT cams
680cc bosch injectors
aeromotive fuel pressure regulator
Walbro fuel pump
Q45 throttle body
magnaflow exhaust
JBA headers
GM LS1 ignition coils
shortened aluminum oil pan
custom motor and trans mounts
Drivetrain specs:
Nissan 6 speed tranny
driveshaft shop axles
cusco LSD
LS automotive custom shift lever
Exedy twin disc clutch
and a custom adapter plate
