1 - 2 of 2 Posts
I did this in my Nissan Armada as well - see post 4 of this thread:
Amazon Coin Holder added - Nissan Armada Forum: Armada & Infiniti QX56 Forums
also, if anyone has the center console tray coin holder (long narrow one) ill buy it from you?
So what I did is i purchased on ebay the mazda protege coin holder from 1999-2003 or so time frame.
It actually snaps into place as if it was meant to be there and looks semi OEM.
Removing the lower panel is super simple, just two screws located on each side on the bottom then pull and it will fall into your hands.
Use a screw driver and pry out the blank that's in that location and your done.
The mazda one snaps into place.
Figured i would share:
thanks,
-J
1 - 2 of 2 Posts
